Ieatlean
Hello there,
(I hope I put this in the right place on this forum)
I got a Sony TC 377 Reel to Reel tape machine recently, it spins fine, and I can FF, reverse and change speeds with no problems, but when monitoring the tape, there is an extremely loud hissing noise which makes the tape unlistenable. As far as I know the tape is an empty tape, but when recording something on it most of the high frequencies get lost. I mean, it can play the things you record in it, but the noise is always louder than the recording no matter at what level you record...which is pretty annoying. The guy that I bought it from told me he replaced the motor capacitor, the quencher and demagnetized the tape path (and some other things which should be irrelevant to the issue). I did clean the tape heads, but it didn’t make any noticeable difference. The Noise only comes when the tape is being played. The tape has a shiny brown side and a matte brown side, but it doesn’t matter which side I’m playing, the noise is still there and remains unchanged.
This video right here shows the noise problem:
https://drive.google.com/file/d/1gu0-MzzYWpZfeWLTqQlU8l471f_7yGRn/view?usp=drivesdk
Is it a problem of the tape itself or is it, like someone on Reddit said, an issue with the bias oscillator? I’d gladly accept some advice.
Thank you for reading, and thank you for your help
