hippo008
I was given a free Sony TC-640 reel to reel deck. It functions properly outside the lock on the record lever. The deck records onto tape very well, playback seems normal. The issue I am having is that when you put the deck into recording mode and press play + record at the same time the deck will lock into play mode but not record. If you hold down the record key the deck will continue to record until you release the record key.
I took out the button array and I noticed there is no locking slide on the record key like the rewind, play and fastforward keys have. What could be going on here?
