lexmarks567
Hello.
I have a Sony TC-765 Reel to reel 4 track 2 channel duel capstan drive 3 motor 3 head reel to reel tape machine. When I got the unit the pinch rollers were gummed up and would not engage. I got them freed up but now I discovered the tape has no tension. The tape jerks and ends up getting eaten as the left reel or supply reel just freewheels as it's pulled. Doing some research I found that the issue is the left motor is not staying energized or the relay is not staying energized during play. The motor spins up for a second with no load but then freewheels down. It gets power for like a split second and that's it. Rewind and fast forward work no issues. I checked the fuses and all check out. The relay is a Omron LC1-C-US-DC24 which is 24 volts DC. it also says 25X7D on it also. The closet replacement I can find is a Omron LC1-C-UA-DC24 with 1512D on it. Are they compatible and am I chasing the right problem or what else should I look for or try?
