WAFOE
Member
Hello, it has been a while since I have last been here - almost 4 years now.
Recently I picked up this Sony TC-K61 casettedeck in not working order for 10 euro's, claiming it won't play. Probably needs new belts I thought, worth the try for a decent 1980s deck. Getting it home and opening it up, the belts are actually in fine shape, if not a bit dirty. Why doesn't it play then?
I noticed the mechanism to lift the heads up to the casette doesn't work, since the cog for it turns very slow and the mechanism cancels the play before it is able to reach the idle wheels. If I give it a little push with a screwdriver or something, it starts to play the casette just fine. It had a little bit wow and flutter but cleaning the heads, rollers and idle belts with alcohol seems to have fixed that issue. I didn't take a look at the belt inside the casette mechanism though since it plays fine now once it started.
I have found pressing the pause button and then play it won't automatically cancel the play, which gives the cog time to move. The cogs make an awful grinding sound, but after that the heads go up.
A video probably says more than my words:
I thought maybe lubricating the cogs would fix the issue, but I'm not sure. Before I try anything stupid and destroy the thing, I thought I'd make this post asking for help!
