BilboBaggins
Addicted Member
I purchased this deck about two years ago. It had an issue with the door not opening consistently so I got it cheap. I took it off the shelf to work on it last year for a few days, and today, I decided to bring it back out to try and figure out what I need to do.
On first look, I realized I changed a belt for a rubber band last year. Had one lying around and no belts. So I know I need to replace the belts. There are at least two of them. I'm now wondering if the door opening issue is related to an incorrect or failing belt that will get replaced. However, I don't want to order a belt kit and then order something else afterwards if I can avoid it. So I'm wondering if there is any Sony ES known issues relating to the door not opening consistently. It closes fine every time.
Finally, can anyone suggest where to get a belt kit for the Sony K707ES cassette deck? I've had some bad luck in the past.
It is a really nice deck. It played fine at first, but I noticed speed distortion, so I'm thinking that rubber band is starting to fail.
I looked for it, and couldn't see it anywhere. I checked my clothes, all over the transport, and it was gone! My best guess was that it fell inside where the small belt goes, so back to de-assembly. There it was!
I put everything back together, and the door opened on power up! Tested it a few times and that was good! Tried fast forward and rewind, all good. Then I tried play. That didn't work immediately, but after fast forwarding and rewinding my test tape a few times, playback started! Success!
