Sony TC-WR610 - Pinch roller pin replacement, Reel Gear Pivot Frozen
Johnny_Law
o.O
Put new belts in my TC-WR610. Was psyched that tape B worked great forwards and backwards. However tape A only worked in one direction.
Hmm ... what's missing?
Oh wait, I found it banging around inside!
... But, the shaft (axle?) it rotates on has gone AWOL. Can anyone please point me towards a good place to source a replacement axle?
Thanks to some advice from Terry at Terry's Rubber Rollers, I found that a drill bit was the perfect size.
However, I have uncovered a new problem. When I hit play on tape A, the capstan / pinch roller now work great, but the gear that turns the take-up spool fails to engage. I attempted to take a video in action but my device died - stay tuned.
Ok here we go. Tape A (the first one I try) you can see the little yellow gear doesn't engage. Tape B (on my second try - woops) you can see the same gear engage properly.
Any ideas as to what's wrong would be appreciated. In the meantime I'll be disassembling and inspecting.
Turns out the pivot for the idler wheel between the capstan gear and the reel gear just needed to be lubed.
Took a silly little video to illustrate.
