toads
Hello, AudioKarma friends.
My boyfriend has recently gotten into cassettes (hipster) and purchased a Sony FX-290W Walkman for just under 10 dollars. The seller claimed that the right channel was dead but the device was otherwise in good shape and you can just unplug the headphones slightly and hear through both headphones.. I gave him the go-ahead to buy it thinking it would be an easy fix. I thought it was probably just a bum solder joint somewhere or maybe the headphone jack was dirty or something stupid like that. We get the device and I pop a tape in and sure enough the right channel is dead. I took it apart and didn't see anything glaringly obvious, but still reflowed all the headphone joints and all the ribbon connector joints from the tape head. Pop the tape back in and NO change. Bummer.
Then I tried the radio.. and the radio works through both head phones..
Uh oh. This may be tougher than I thought.
Since there are only a few electrolytics on the board, I figured I would test those next. Maybe a coupling capacitor or something.. but all the electrolytics seem to test fine in my little tester. Capacitance is pretty close to what's expected and low ESR across the board. (I circled the ones I tested).
I then went and reflowed just about every joint I could find on this side of the board, but still no fix.
And of course during this process I managed to tear the ribbon connector so then I had to solder some wires to fix that. It's back to it's former state but I'm nearing the end of my ideas. ChatGPT keeps recommending garbage and I haven't found a lot of videos dealing with walkman repair except for replacing the belt.. I know how to replace the belt -_-. I'm just wondering if you all have any suggestions or if I should just give up on this and call it a loss. The worst part is my boyfriend is fine with just keeping the headphones half plugged in. It would drive me absolutely INSANE to have to do that but alas..
