Good for you. I know people with working Sotas and they don't complain about speed instability. If you read the very first review of the Cosmos in 1989, speed instability was noted right away. A few months later Sota sent another unit with some changes, and speed stability was greatly improved. I guess my unit was of the first generation. I also love it's SQ, but I don't care anymore to put a $1500 into it hoping that it solves this problem.I have a working sapphire and love it. Sorry it didn't work out.
Wow, I just realized I reassembled my Sapphire in the Summer of 2015. I know I re-lubed and checked on the Phil's about a year later. That means the most recent lube was after 4 years, not 2. Pretty good for that Phil's Tenacious!
HiHave you ordered that OEM belt yet?
Audiofreak71
These are great figures! I wish mine was like that. I have the same app I think, but it looks different. My lowest figure I got today was .21%, which sucks. That’s the very top test in photo.This is the reading I got on my early SOTA Sapphire Star today using "RPM Speed Analyzer" app for Android.
This was from a cold start, I didn't dial in the speed beforehand, and I just recently re-lubed the spindle with Phil's Tenacious Oil. Belt is OEM ordered directly from SOTA circa 2015.
Thank youThe SOTA tables I have and have seen, use “oilite” type, sintered bronze bushings which are oil impregnated. I believe the oil that comes in them is -around- the same as a 20-30 weight automotive engine oil. You basically just want to clean them off and soak them in a similar oil, remove any excess and then reassemble. Use just enough grease on the sapphire/bearing to hold the ball in place. I think that any heavier weight or stickier oil shouldn’t be on oilite bushings.
Thank you
This is true. Question is - how do you “soak” then? If I feel the bearing opening where the bushings are with oil, it will leak out through the vacuum channels, and will completely clog them. After 32 years I think these oil bushings no longer hold any oil. I look at them and see the micro chambers open. When I got the table with that horrible wow, the bearing was lubricated with some yellowish oil that felt like auto oil.
That one looks much more worn than mine did. Mine was only marked from use, not dimpled like that one. Those are available on ebay, btw - but contact the seller to be sure of size. They claim theirs is for “early Sapphire”.And here’s the wear on the sapphire thrust plate. I’m not sure if it should be replaced or it’s still ok. This is a pretty strong magnification, stone plate is actually only about 3 mm in diameter.
If the steel shaft fits smoothly and doesn’t show much wear, then the bushing is probably OK too. If it’s a sloppy fit, then you’ll need a replacement bearing/platter assembly. As far as removing the old sapphire thrust; they should shatter by using a steel punch/drift and a hammer. You’d then need to carefully clean out all the tiny bits and any adhesive, before fitting a new thrust. If you don’t feel up to it, you’ll want to contact SOTA about getting a replacement assembly.This doesn’t look good to me either, bushings surfaces are covered with micro pitting?
