Sound Technology SG1000A Special Modification Type 2995-9577
Longnosegar
I recently bought a ST1000A, and it has a Special Modification Type 2995-9577. It has an additional circuit board and a 8-9 wire connector in the back. Could this be a prototype? I emailed Sound Technology and Stan Curtis with no response. I didn't get any leads with it, and I am just waiting for a few parts so I can make the ST100 matching transformer.
  1. What does this modification do?
  2. I am curious if this modification will change anything related to FM alignment?
  3. The Pioneer (SX-939) and Yamaha (CR-820) receivers I will work on both have 75Ω & 300Ω antenna connectors, is there a benefit to using 75Ω (ST105) vs 300Ω (ST100) matching transformers?
Thank you for any input.
Probably some special function for a specific customers needs.
I could suggest to reverse engineer the pcb to draw up a schematic and figure out what it connects to in the schematics which we do have.
Emailing sound technology, interesting, where would you get their email address? I would have thought they folded before there was email, but I do not know for sure when they stopped their operation.
Try posting on DIYAudio as well in the test equipment section
Good luck
Shot in the dark, wondering it's for some type of external modulation. Possible SCA or to use the generator as a low powered transmitter.
I have actually run my stock 1000A as a low power transmitter. Its got L and R inputs and a position on the front for external modulation input. Wire it up and you get a rather good but low power FM transmitter.
Good luck
I had to pull the board out to do an inventory of the components,
Quantity Chip Description
1 RCA CD4016AE CMOS Quad Bilateral Switch
6 MCT2 Transistor Output Optocoupler
2 2N3970 N-Channel JFET
1 2N3414 NPN SILICON TRANSISTOR
1 2N3016 BJT NPN Transistor
I don't think these really spell out the function of the board. when received the unit, the meter glass was smashed to the face, and I thought it was a dummy meter, and the
plug in the back was for an external display. I fixed the glass and the meter is fine. My other thought was that it could be M3 modification since it seems to be mounted around the same place.
I will check out diyaudio.com.
The company still has a website, and even offers service and calibration of old units, but the website seems to be from the 1990's www.soundtechnology.com/service.html
Thanks for the info.
it just modulates whatever you put in, so to make it sound truly right it would need to have that added to the input signal
Did you ever find out what this mod does? I have an ST1000A with the same mod and I'm clueless
