Racingh11
I recently bought a Soundcraftsmen DX4200 preamp equalizer to go through and sell. It was already an unusual unit, it does not have rack handles. First time I have seen that. I also noticed it felt heavy. Upon opening the top cover, I found a big attempt at reducing noise in the power supply section. This thing has power caps added that are big enough for a power amp. It also has a line EMI filter, and what looks like a couple chokes on the DC side. The rest of the unit is factory stock. I tested it out on the distortion analyzer. The preamp section came in at .001% THD+N, and 103dB S/N relative to 2 volts. They are usually about .0015% and 97-98dB stock. Those improved numbers are about what I get with replacing caps, ICs adding local film caps, and moving wires to best locations. I will retest after I service it. It's also getting new sliders. The THD is about as low as my equipment goes, so I'm not expecting much there. But hopefully I can see further improvement in noise reduction.
