thedelihaus
Nocturnal transmissions
Was given a table saw yesterday.
Needs brushes, and motor is arcing, but hopefully replacing the brushes will cure that.
I'm going to build some amp fans out of wood and computer fans, and maybe some mesh metal. The kind that the metal ADS grills are made of.
With luck, I'll find a damaged ADS grill on eBay, or some similar perforated metal.
I'll finish them off with either a nice wood frame stained and polyurethaned, or in a nice satin black finish. I may even gold leaf a brand name on them (Yamaha, Sansui, ect) or put Audio Karma's logo on it.
So, I'll need a source for electric fans and the metal mesh. I found a source already for a cheap adjustable wall wart.
I'll build one for Audio Karma, and have Lovinvinyl set up an auction to benefit AK, if he'd do so.
But first I need to fix the saw, and locate the parts.
If you have any sources for really cheaply-priced, quality fans, or that mesh metal, please let me know. Also, if you have any insight on that arcing fan, as to what may be the cause of it arcing (hopefully just the brushes), that'd be swell. :thmbsp:
Needs brushes, and motor is arcing, but hopefully replacing the brushes will cure that.I'm going to build some amp fans out of wood and computer fans, and maybe some mesh metal. The kind that the metal ADS grills are made of.
