Unfortunately not that I know, plus IF you find a 3900 list that has 140- mouser part numbers , THAT is for xicon caps and is highly NOT-recommended!!!
in mouser, on the search line, looking for a 47uf 50v cap, typing :
47uf 50v UPW and hitting enter will give some selection boxes cuz it was confused, select the 47uf and the 50v and check the stocked box and hit apply filters.
that will give you 647-UPW1H470MED at $0.25 each.
omitting the 50v part (type in only 47uf upw) would get you a range of voltages.... so you shouldn't get stuck, say if they were out of 50v caps... then go for a higher voltage......
There is no 80v there is 50, 63, 100.
wish i had time right now to do a list, and unfortunately the BOM is cryptic, so you need to find all the 1uf + caps on the gwr-122 power supply board from the schematic.
Post the list if you wish and I'll look it over at oh dark hundred or so...
edit: I grabbed a list of the caps I commonly keep around
stock number microfarads volts cost
647-UPW1H010MDD 1 50 $0.12
647-UPW2A1R5MDD 1.5 100 $0.15
647-UPW1H2R2MDD 2.2 50 $0.12
647-UPW2A2R2MDD 2.2 100 $0.14
647-UPW1H3R3MDD 3.3 50 $0.12
647-UPW1H4R7MDD 4.7 50 $0.12
647-UPW1J6R8MDD 6.8 63 $0.15
647-UPW1H100MDD1TD 10 50 $0.12
647-UPW2A100MED 10 100 $0.25
647-UPW1H220MDD 22 50 $0.19
647-UPW1H330MED 33 50 $0.24
647-UPW1V470MED1TD 47 35 $0.10
647-UPW1H470MED 47 50 $0.22
647-UPW1J470MPD 47 63 $0.28
647-UPW2A470MPD 47 100 $0.36
647-UPW1A101MDD 100 10 $0.14
647-UPW1H101MPD 100 50 $0.22
647-UPW1J101MPD1TD 100 63 $0.18
647-UPW2A101MHD 100 100 $0.53
647-UPW1A221MED 220 10 $0.18
647-UPW1V221MPD 220 35 $0.22
647-UPW2A221MHD 220 100 $0.80
647-UPW1A331MPD 330 10 $0.20
647-UPW1E331MPD6 330 25 $0.28
647-UPW1E471MPD 470 25 $0.47
647-UPW1J471MHD 470 63 $0.52
647-UPW2A471MHD 470 100 $1.15
this list MIGHT entirely cover the 3800's power supply... good luck
(prices may be slightly ($0.02) low, I buy in quantity for the discounts......)
