That's a tough one. The tweeter is really what gives the SP-70 it's characteristic sound (or more specifically what distinguishes it from other Sansui speaker models of the era, most of which used horn tweeters) so changing it is a crap shoot in terms of how close it will be to the original sound.
A decent soft dome, mylar dome or titanium dome tweeter - of identical physical size - at 8 ohms would work without butchering the baffle board, and perhaps be perfectly satisfactory. Because the specs (other than impedance) of the T-1001 are unknown, it isn't possible to try and match it exactly.
I'll add that these tweeters seem to be very highly failure prone. Whether that is due to design and age, or previous abuse of the speakers with excessive power levels isn't known, but I've had similar issues with numerous other Sansui drivers going open on multiple other models made between 1969-1973. Mostly tweeters and mids, no woofers so far other than those that were clearly physically damaged by puncture or water.
It's a shame, because the SP-70 in particular is one of the better efforts Sansui made in speaker design as a simple two way setup, and with a dome tweeter, which was unusual for them at the time. The T-1001 was used only in the SP-70 and SP-1001 (which was it's original application, hence the designation T-1001).
