Swapped boards tonight and things are starting to make sense! First thing I found was a jacked up molex connector, where one of the wires was backing out and not making connection! Bingo! Huge find. Then after a drop of super glue to keep that wire in the molex, I swapped boards, and set the dc offset on both boards... no problem. The bias set great on the right side (formerly on the left), but the bias on the left channel (formerly right), still was way too sensitive to set. THEREFORE, it appears at this time all I need is a replacement bias pot. The 25 turn Bourns should be here for the weekend. This hobby can really test a guy! But it is great to know there are people out there to keep us plugging away, probing and pondering until things start to work out!
I may still need help before this is over, but THANK YOU sanjib for all your help thus far!
