ozmoid
Lunatic Member
The A channel on my SX-770 went completely out. I have NO electronics experience, but having gained a little confidence from the projects you guys take on here, and knowing I had AK looking over my shoulder, I cracked the case to see what was up. Years of using home-grown solutions, instead of buying those #%$* pioneer connectors had split the bakelite block into little shards, and the clips were just hanging loose inside the case. (And BTW, that's a dad-jim tight little hole those blocks are mounted in! No access from inside at all!)
Nudie of the open case, and a shot of the clips hanging outside the case after I removed the busted block (red circle).
