avantbored
Hi all,
I disassembled the head module on one of my KEF 105.2 speakers to try and replace an LED that glows at various wattage readings and helps you position the speakers. I decided I'll try to clean the connections (there's a small PCB in there) instead. Used Deoxit F5 and D5; sprayed visible front, and invisible rear, behind the PCB. Not sure what's back there but as it was Deoxit I thought it'd be okay.
Hooked them back up and was fine. Then that speaker cut out until I upped the volume on the preamp. Sound returns. Has done for a few times. Distortion in the tweeter and and nothing in the mid.
Any ideas what's happening there?
