Speaker Destroying Playlist
There is a drum solo on one cut on the second side of Emerson Lake and Palmer "ELP" that is a real killer. I think the song is "Tank." My friends and I used to use it to test speakers.
Also the first cut of Pink Floyd's "The Wall" is good. It took out a woofer in my old AR 1's. Of course it was probably close to 40 years old...
Yes, good choice, Tank is a speaker killer, but not as much as the version of Lucky Man found on Brain Salad Surgery , bonus track- DVD Audio. Deep , deep bass on the Moog.
One of the few recordings that I have that will trip the Powergard lights on my Mcintosh amp , but you feel isn't really that loud.
I just played "The Nurse" by The White Stripes and was able to locate each and every place on my drivers where the rubber surround is starting to come away from the basket on my vintage Hafler model 400 speakers. I went over both speakers with Loctite contact cement and all is good again. The first 10 seconds of the xylophone will help you trouble shoot ANY vibration issues with your cabinets or drivers.
Thanks for the explanation, I figured these shitty PC speakers rolled off at a 24db/octave rate around 100hz...lol
I'll order that CD today and put my woofers to the test in the Honda CRX system with (2) 18" woofers
Oh hell ... I mean ... ah well ... I was hoping you was gonna take my comments about your pc speakers the wrong way. Least I could do seeing you're being so nice about it is to give you an opportunity to laugh at the sub in my Aurora ... ;-}
My powered Audiobahn 12" does surprisingly well for it's size - the trunk is ported, which helps a lot - but I wouldn't want to enter it into a bass off against dual 18s ...
I once destroyed a woofer surround with Can's "Last Night Sleep" from the Until the End of the World soundtrack.
Destroy your tweeters and possibly the mids with Pink Floyd's 'Time 'off DSOTM and while you're at it might as well throw the woofers cones across the room with Telarc's 1812 Overture cannon shots...A surefire way for full loudspeaker destruction..
Matt..tubeornotube
Matt..tubeornotube
I got that Telarc - it's a cantilever integrity test in the guise of a record. Blowed up some early Time Windows with it at the store, too.
I destroyed more speakers with Space Truckin' live from Deep Purple ~ Made In Japan than anything else.
Some very nice contributions here and have to agree with those I know about, Telarc 1812, ELP, etc. The one song that actually destroyed a pair of my Kefs was Jethro Tull's Locomotive Breath from Aqualung. I think the damage to the drivers was minimal, but it exploded little white pinky-tip sized components inside the speakers which singed the filler/damping material inside the speakers.
The repair guys were rather impressed. I was rather embarrassed.
Boy, I missed what you are talking about on this one, I went to Youtube and played the song and its just a standard slow song.
Same thing with the song "Hidden", and the one from Dead Can Dance, Sounds From the Ground, they all sounded like normal songs...must be unable to play all the subsonics on my PC speakers, do they all have subsonics or something else I'm missing?
Yes, PC speakers will not reproduce the low bass. The solution: 1. Hook up computer to music system (provided your speakers can reproduce the lowest octaves). 2. Play track.
"Bachbusters" and "Beethoven or Bust" by Don Dorsey on Telarc CD. Liner notes tell you to turn it down until you find a good level that won't destroy your speaks.
Tom
Im Traveling Light-BB King & Diane Schurr has crazy acoustic bass all throughout,CRAZY!
Down at the Pawnshop-Sublime
Dance on a Volcano-Squonk-Genesis,Seconds Out
Chili Peppers-Assorted tracks sneak up on you hard
Wish you were here-Floyd
I agree about Locomotive Breath too,great track
Working Man-Rush just cause I turn it up so damn loud!
The Power And The Majesty Vol 2
The Choo-Choo that will run you & your system over is on Track 4...................
+4 on the PT Russia On Ice suggestion......it has a middle section as well as the end section of low end synth drone.....The Epos handle it very well and I can crank it pretty good.
But it does shake the sofa pretty good!
Fantastic song BTW
Was just listening to the soundtrack from Sucker Punch. Army of One by Björk will really work the system. Fun watching the needles on the amp bounce off the scale and the protection lights glowing on the speakers ... even more so than Russia on Ice (Porcupine Tree), or Chocolate Fudge (Manneheim Steamroller), which I wouldna thought possible. Maybe just a bit scary at a couple hundred watts per channel.
Your fun filled fact of the day ... Björk is her real name - last name is Guðmundsdóttir. In case you ever wondered - well now ya know.
Eruption Van Halen does a number on tweeters and crossovers...
We went through two sets of Sansui speakers in a weekend playing that on the roof of the frat house... Both replaced under warrantee, by different repair managers thankfully. :D
I second/third/fourth Telarc 1812, ELP Tank, and Power and the Majesty (Except I have the first LP, can't say how it compares with Vol. 2)
Napalm for breakfast, rhythm devils play river music.
2:19 on.
If you have true sub 20 hz reproduction, at 2:19 he strikes the beam twice, the first strike is the softer one, if you don't have true sub 20 reproduction, the second strike will be weaker, and it will seem to just fade out. If you do, the second strike is absolutely thermonuclear, and you get a solid minute of amazing dynamic BASSSSSS :drool:
yes, this will blow up speakers, so don't be fooled by how quiet it's getting from 2:00 on. play at very conservative levels until you find your 'safe' spot or that you simply don't have any subterranean bass reproduction.
http://mickeyhart.net/discography/the-apocalypse-now-sessions/
I also have the Dead Can Dance cd, and agree, and I even have that digital domain test cd somewhere still.... but this track is the end for bass. It even beats the damn cannon/kettledrums on 1812.
another great one is the recording dafos, mickey plays the beast ( a completely suspended monster drum kit) he raises the entire kit one inch off the floor then drops it. such an amazing WHOMP-boom-ring-chime-rattle-
http://mickeyhart.net/discography/dafos/
Gates of Dafos is the track with the 'beast' being dropped.
http://www.psaudio.com/paulsposts/2011/12/21/drop-drum/
jaz
Artist: Alarm Will Sound
CD: Acoustica
Most tracks on that CD most speakers will not hit the lower octave on.
Try the track "Blue Calx" it shakes the room with my speakers. Bottom octave completely intact. Powerful room moving bass minimal driver excursion. If you speakers can take it they are pretty good.
Also track "Gwely Mernans"
jaz
A lot of Mickey Hart is good material to "stretch the limits" of your speakers bass capabilities.
Try this
Marti Jones
CD: "Live at Spirit Square"
Track: Percussion Solo
Sound tracks to modern movies are done with subterranean bass. Some way over done. Dark Knight gets them rocking. Transformers.
I love the WALL-E soundtrack.
