Speaker driver ID help needed
myc5
Member
i can't find any info to identify who makes this driver so I'm throwing it out there to see if I get lucky. It's a beefy 10" woofer. The codes don't correlate to anything I can find.
The picture is upside down for reading the numbers.
Is 1054 one of the numbers?
1056 Gefco
I recall Gefco being a pretty good OEM and contract maker for a lot of companies, but have never heard of or seen much documentation of their drivers or parameters, probably due to the propriety of design choices by the end maker/user. I think there have been a couple of threads about a few of their drivers on AK.
1048 could be a date code, let's see, that would be the 1st day of the 4th week of a year ending in 8. '68 or perhaps '78? SVC might be a plant code. No idea where Gefco made their stuff. Leaving 8914 as (perhaps) the model number.
I think you may be on to something with Gefco and the date codes. I couldn't find any info at all with any of the codes but what you guys have mentioned makes good sense. The numbers are 1048, 1056 and 9914. They are in a pair of Ohm C2's that I knew were obviously not original drivers but they sound excellent and very similar to my other C2's that are original. I think for fun I'll get around to running some TS parameters to see how they are matched up for the C2 cabinets. I am willing to bet they are not far off based on what I am hearing.
Thanks all!
I knew I was probably screwing up that date code thing. Thanks bowtie. I don't know the production dates for the Ohm C2 but '99 sounds like it's in the ballpark for a replacement driver.
I saw that as well but I would be surprised if it were a Fisher driver, not that I am an expert about that but I just don't remember Fisher making anything of this level of quality, especially in 1999 which seems about right for this driver looking at it. That's why I started questioning what it could be.
I also wonder, but doubt, if this is the upgraded woofer that Ohm provides. I've never run across a unit with the upgraded woofers so have no reference to compare. I would also think they would have idenitfied it as an Ohm driver if that were the case.
