Hello!
I am working on a set of Snell K/II speakers that used the 4 ohm Peerless woofers (831876 model number on the back of the driver). As far as I can tell, every other variant of the K or K/II used an 8 ohm Vifa M21WG0x08 woofer.
I am looking for help in understanding what, if any, changes need to be made to my crossovers to get the Vifa woofer to work. OR, I am looking for T/S measurements of the Peerless woofer so I can find a suitable replacement.
Also note, the recessed opening for the Peerless version is 210mm, and the Vifa woofer is 215mm wide. So even if I used the Vifa woofer, I'd have to modify the cabinet. Would like to avoid this, so measurements for the Peerless would be preferred.
THANKS!
THANKS!
