Hello! Lately I've been struggling to wrap my mind around impedance and wattage. I have 4 ohm 90 watt rated speakers and amplifier rated at 8-16 ohms and 50 watts per channel. I have searched and searched for information but i can not make it sound logical. If amplifier wattage for 8 ohms is 50 watts then at 4 ohms it will be 100 watts. So speaking from numbers the amplifier will be able to support the speaker. Then why everywhere i search it says that i should not overdrive the amplifier cranking the volume up too much. Why if the amplifier at 4 ohms is 100 watts and the speaker is 90 watts. Like where is the missing link that would finally make it clear why i can or can not cross impedances and watts?
? You did not mention what that is and I am thinking it would certainly give a measure of the demand put on your speakers. Also, there is the dynamic range that is quite different from the nuances of spec related to your amp and speakers, including the impedance.
