speaker insulation
james m
i'm recapping my dlk 2's and when i took the speakers apart i found the insulation rotted and falling apart. i'm thinking about using 3 inch acoustic pyramid foam will this be okay? this speaker is a three way with a port tube. any help would be great. oh and the old insulation stinks like 40yr. old mildew
It's called damping.
There are many products you can use/try.
Rock wool, egg crate foam, polyester fill
What was in there to start with James
Be prepared to experiment with different amounts of pad. I've found that too much foam actually created a harsh, annoying bass in some "augmenters" that I made for some satellites, but too little can give you a mushy, free of punch and definition bass.I actually wound up using a combination of 2" pyramid (bottom and back) and 1" polyfil (sides and top) to get the timbre that wasn't fighting the satellites. The dual-woofer towers needed 2" pyramids on the back with 1" around the sides, top and bottom.
Unless you've got a giant enclosure, 3" pyramids may put a damper on your versatility (as opposed to 3 layers of 1" pyramids).
