Speaker integration: Help, please
hamblis
I have a pair of Usher Dancer 8571 ll speakers on trial and have some trouble setting them up properly. The bass performance is better when I'm standing than when I'm sitting.
So far, I've moved the speakers back and forward from the starting position (which is 4 feet from the rear wall and about 4'6" from the side walls). The changes seem to make no difference.
I've also tried adjusting the rake of the speakers, using small, .75" blocks of wood under the points. Raking forwards made the sound very thin, although consistent from sitting to standing. Raking backwards provides slightly better continuity but not enough to fix the problem.
I'm going to try thicker wedges of wood but I wonder if anyone has experience of this problem and some tips for fixing it?
Interesting looking speakers. Kinda like a cross section of an airplane wing. 12 grand? Yikes!! Have you tried removing the spikes? Do you have them on a carpet? They are floor coupled for sure, similar to NHT's, Allisons and the like. I've experienced the same phenomenon with speakers having woofers positioned near the floor.
Thanks for your response. They are large - like the prow of a boat hull, perhaps, more than an airplane wing. They are, though, very well proportioned and the build quality is almost up to Sonus faber standards. Certainly expensive but the sound quality is exceptional, so long as I can fix the top to bottom integration.
I will try taking the spikes off but that would put the woofers yet nearer the floor. They are on carpet but it's thin and the spikes are into the floor - are you suggesting that carpet is bad?
What does the room look like? Generally the room will have a big effect on bass.
Ray
Not necessarily as long as it is not the thick plush. You could try them coupled directly to the floor sans carpet and see what happens. You may find an overabundance of bass on a bare floor, however. I have a couple of rooms in my house where the dimensions are definitely not bass friendly. The best listening room in my place is a rectangular room with an arched ceiling and no large pieces of furniture that might tend to absorb sound.
Room question: I know that rooms are a big part of the equation. Mine is 21' x 16' 6". It has a chimney breast on one side wall and at both ends the ceiling slopes from about 4' out from the end walls. I have the speakers well into the room, at the point where the slope starts. The issue I have is not lack of bass overall but that it is full when I am standing and is diminished when I sit down.
The carpet is a thin one, not thick or plush. I won't get away with no carpet - my wife is long suffering but has been known to turn a little and I think she'd see that as wanton antagonism....
I'll get the spikes off this evening and see what effect that has.
Thanks for your thoughts.
Wanton antagonism? Surely no man would even ponder the thought. At least, not if he valued his manhood. Zilch gave you some good info. You may find a revelation in there.
