Speaker Loads Main And Remote
Meaudio1
AK Subscriber
i am well aware that 4 ohm loads are much tougher for any amp or receiver. My question is: are main and remote speakers completely separate loads on all or most receivers. Is it dangerous to run two sets of 4 ohm speakers on most receivers as long as only one set is being listened to a one time? Also what if I have one set of 4 ohm speakers on the mains and an 8 ohm pair on the remote. This type of multiple speaker hookup to one receiver would save me space and I have no intention of running both speaker sets at the same time but would switch between them. Is this dangerous especially since many receivers do not even state 4 ohm specifications?
It's not how many set's of speakers that are connected that is the issue, it's how many that are selected drawing load. I'd stick with the one set of 8 ohm speakers until you can dig up some specs. Usually there will be a label on the back at the speaker connectors that will say something like A: 4-16 ohm, A+B:8-16 ohm etc. A lot of the lesser expensive AV receivers will only take down to 6 ohm speakers for fronts, centers, and rears. But that is not always the case. I've got a big Yamaha RX-V 2092 (from the late 90's) that weighs in close to 50 pounds that will go down to a 2 ohm load and will drive 2 sets of mains (4ohms each), one set of front effects, center, and rear. I've got a few concert DVD's that are just fabulous with all the speakers going. Of course she does tend to get a bit warm!
