robinjhorn
Hi everybody,
I,m looking for some help and advice with an amp I've just bought for my workshop. After a little trouble finding the right type of amp (and buying one wrong one already...) I've gone for a Pioneer A-66x, an "ok" late 80's amp which I suspect will be good enough quality and power for a large noisy workshop. It's rated at 80w per channel into 8ohms and crucially has two speaker channels that I intend to use (needing both channels was my problem with finding a suitable amp for a low price.)
The problem I'm having is that I've currently already got a set of Mordaunt Short Ms10i's and some Leak 2060's that i was wanting to use in the small and big space respectively. Having bought the amp though I've now discovered that the channels are rated on the back of the unit as follows:
A: 6-16ohms / speaker
B: " " "
A+B: 12 -32ohms / speaker
Here's Hifi-engines specs: http://www.hifiengine.com/manual_library/pioneer/a-66x.shtml
With the MS10i's and the Leak 2060's both being rated at 8ohms and15-60w and 50w respectively I'm concerned as to what the repercussions are and how im interpreting the channel ratings...
In my head the A+B channel rating suggests I need at least 12ohm speakers on each channel and ideally 80w or higher max input. Is this right?
Now I'm not massively concerned about the wattage as I doubt we'll be going much past halfway on the volume. We only want enough to hear the music not to have our faces melted.
but I am concerned about overworking the amp and damaging it (or the speakers for that matter) with this setup.
I understand that this is fairly basic stuff and have made some efforts to check my reasoning but at the moment I'm hellishly busy and am resorting to asking for help from the community as I really have no spare time at all!
Any advice would be much appreciated, I'd like to use the speakers I already have as I cant justify buying more on the business expenses but if this amp is a terrible idea for them (or vice versa) then I may well sell it on and buy another...
One option i thought of was to get an extra two pairs of cheapo skeapers to wre up to each channel in series to up the resistance? Would this work if necessary?
Cheers,
R.
B: " " "
Cheers,
R.
