Dan13105
Well-Known Member
The biggest problem with nominal impedance ratings like 4 ohm or 8 ohm is the manufacturer gets to make the determination. There are standards for rating 4 ohm and 8 ohm speakers, but it is easy to find speakers that break the rules. Take my current speakers for example. They are rated at 6 Ohms, which may make you think they can be driven by a 30W receiver that claims it can drive 4 Ohm loads. Well the problem with that is, they are only 86Db efficient, so they require more watts to get them moving. Then there's that impedance dip to 1.1 Ohms that few power amps can deal with. Most receivers or even stand alone power amps are not built to push power to a 1 Ohm load. Then there's the infamous Infinity Kappa 9s, rated at 4-6 Ohms, but with a nasty dip that can hit slightly below 1 ohm. They earned a reputation as amp killers. Not all 4 Ohm and 8 Ohm speakers are created equal, and some "8 Ohm" or "4 Ohm" speakers truly aren't
