Speaker terminal block
Sedge
Member
I'm in the process of updating a 1969 pair of Klipshorns. There is a speaker wire terminal block mounted in the bass chamber access hatch that's original, but doesn't appear to be very high quality (zinc?). Any-who, can someone recommend an upgrade for this little item. It now seems like a weak link in the chain from the woofer speaker to the crossover.
Don't see much after a casual internet search.
Thanks!
Oh hell, I posted stuff you would need to type in, just click the links in the post below.
Nothing beats the old fashioned screw terminal blocks for a secure gas tight connection. Banana plugs suck.
I work on industrial gear that may have well over 100 screw type terminal connections in the electrical cabinet and in remote locations, they are never a failure point, even if they get wet and corroded. I would not be able to keep up with the service calls if they used banana type connections instead. Did I mention that banana plugs suck?
BillWojo
I appreciate all the input, and count it towards my "audio education". I have decided to by-pass the terminal block connection and wire the bass speaker direct to the x-over. This will require a small hole in the access cover, and some stuffing for a tight seal, but I don't see any reason to pass through a terminal block...just one less connection. I will leave the original block on in case my heirs want to do further mods...or, I may elect to be buried in cabinets ;-)
