Avogadro33
Member
Question For Fisher Receiver Gurus . . .
For every tube receiver I had heretofore seen, speaker hookup has been the same:
One of the two conductor wires to the receiver terminal “C” (common), the other conductor to one of three impedance terminals: 4-ohm, 8-ohm or 16-ohm. Simple enough.
Now, my new (to me) Fisher 800 (TA-800) is different (and similar to the Fisher 600 (TA-600)) in terms of the speaker terminals on the rear of the receiver, and corresponding the instructions in the owner’s manual:
The Fisher Owner’s Manual states:
---- Channel A (the left speaker): one conductor wire to terminal “C” (common), the other conductor to one of three impedance terminals: 4-ohm, 8-ohm or 16-ohm. As expected. HOWEVER,
---- Channel B (the right speaker): Regardless of the impedance of the speaker, connect the wire conductors between Channel B terminals “G” and “X”. In addition, connect a jumper wire between Channel B terminal “P” and the other Channel B conductor wire to the Channel B 4-ohm, 8-ohm or 16-ohm terminal.
Can someone explain what this (perhaps obsolete) speaker terminal set-up is all about?
Thank you.
Thank you.
