SoCal Sam
Lunatic Member
Here's a chart that actually contains some useful and objective data courtesy of Peavey Electronics.
DF degrades with wire length. DF is a measure of cone control.
Damping factor degrades with increasing series resistance in the load, wire length is only a part of the equation. Damping factor is the ratio of amplifier output impedance to total load impedance.DF degrades with wire length. DF is a measure of cone control.
Man all you people spend all these hours and days putting together the best system you can find, trading up, swapping out, hiding gear from the wife, figuring out ways to keep the cats off the TT's and the best you can do is lamp cord!
Real Audiophiles would never be caught with lamp cord running to their speakers.![]()
Copper is copper. Size definitely matters. However, that being said, as long as the insulation prevents oxidation, then pay for whatever name or pretty coating you feel you need. Certain cheap insulators (i forget the type of plastic) do not prevent, and in some cases promote oxidation. That is what leads to degradation in sound (b/c of increased resistance). I'm totally against paying hundreds or thousands of dollars for speaker wire and interconnects, but there is a difference in quality (or at least quality control) to a point. There is certainly cheap, well made 16 ga copper strand wire out there to be had. Open up your speakers and see what they are using inside.....it definitely isn't wire that costs 10's or 100's of dollars a foot.
I'm not an "Real Audiophile". I'm not even a fake audiophile. Worst label ever.
I wasn't really serious about the lamp cord, but I would think that the majority of people use a bit better than that.
And that's the crux of the issue, isn't it? Is there anything better than lamp cord? Various reviews, articles, manufacturer recommendations, etc., over the years seem to indicate that lamp cord is not outperformed by the more expensive alternatives, so there's really nothing "better" to buy.
Personally, I tend to buy what my amplifier and/or speaker manufacturer recommends. With Naim electronics, I used Naim wire; with a Linn system, I used Linn wire; with Audio by Van Alstine, I used his recommendation of buying low-cost wire and interconnects from a hardware store. It all worked well.
+1
If you are looking for straight, unfettered signal transmission, then good old multi-strand lamp cord of sufficient gauge is what you want.
As soon as you modify the signal (by altering the electrical properties of the wire - c/r/i), you alter the signal/sound.
When you alter the signal/sound in any way, "better" becomes entirely subjective (extreme analogy - one man's boom and sizzle is another man's dream system), but the fact of the matter is that delivering the purest signal possible is the right way (electrically speaking) to do it, and anything that doesn't do that is technically not "right".
Copper is copper. Size definitely matters. However, that being said, as long as the insulation prevents oxidation, then pay for whatever name or pretty coating you feel you need. Certain cheap insulators (i forget the type of plastic) do not prevent, and in some cases promote oxidation. That is what leads to degradation in sound (b/c of increased resistance). There is certainly cheap, well made 16 ga copper strand wire out there to be had. Open up your speakers and see what they are using inside.....it definitely isn't wire that costs 10's or 100's of dollars a foot.
Hold on there. Please explain this further. Are you suggesting that lamp cord has the ideal properties for wire and has the least impact on the signal? Maybe my scientific bias is making me call BS on this, but I'd like you to explain your position.
Does the type of speaker wire used to connect speakers to a receiver make a difference in terms of sound quality? If so, what is the best speaker wire to use (brand? width? 16 gauge? 18 gauge?)? I am going to connect a pair of Dahlquist DQ 10s this weekend to my Yamaha CR 2020 receiver and wonder what type and size of speaker wire would be best and if it does indeed make a difference in sound quality.
Thank you.
