Speaker wiring - questions - Yamaha A-700
Shredded
Beginner questions on ohms & watts.
Yamaha A-700 amp (1983). 4 speaker terminals.
Terminals state:
A or B 6~16 ohms/spkr
A + B 12 ohms min./spkr
(See pic)
Can I hook up four 8-ohm speakers? (One to each terminal?)
Amp is 100w / channel:
Does each of the 4 spkr terminals have its own 100w?
..Or does A (L&R) as a whole have 100w? (and B another 100w?)
If speakers connected to A-right & A-left, are they in parallel therefore splitting the power?
Thanks in advance for suggestions on wiring options.
It is 100w x 2, the A and B speakers are wired in parallel which cuts the impedance in half.
You can hook up 2 pairs of 8 ohm speakers, but Yamaha recommends that you use only 1 pair at a time, not both.
Thank you. Just to be clear, just connect 1 speaker to A-Right, and the other speaker to B-Left?
No, connect 1 speaker to A-right, and the other speaker to A-left.
It's just a stereo (2 channel) amp, not a quad (4 channel) amp. Your B speakers are just for an extra set of speakers like if you were to have one set in the living room, and one set in the kitchen. The A and B speaker selector is so you can run both pairs at the same time or living room or kitchen speakers seperately.
Like cademan said:
Thanks again! 'A' being internally paralleled to 'B' was the info I was looking for. My setup needs control of turning off each speaker independently, so connecting one to A-right & the other to B-left allows use of the A/B buttons without changing anything electronically.
Really appreciate the info & fast response.
If you got one, that's what the balance control is for.
True..Didn't think of that! Thx.
This is for my business (gym, 6000 sq ft)
While I'm here, can anyone recommend a good modern amp that can take 6 to 8 sets of random 8-ohm speakers at high power? I currently running multiple old Pioneer vintage amps from the 1970s/80s. (SX-980, 1050, A-8, and a pioneer quadraphonic from the early 70s, etc.) After seeing how much these are worth, I'm thinking of selling all the old pioneers & getting one new unit to simplify things. I'm just not sure of what to look for. Perfect sound quality is not a concern.
Thanks in advance to any advice.
Hmm, I would perhaps move away from consumer grade equipment for your particular use. Maybe look for the type of equipment used in department stores or clothing stores, maybe used?
I remember Abercrombe and Fitch stores cranking the jams over multiple speakers. Might be worth looking into.
PA amplifiers with 70 or 100 volt might work for your needs. Lots of options available out there.
