Speakerlab 4 crossover question
that70sguy
Well-Known Member
I need some help regarding connecting the crossover for a Speakerlab 4 to the correct components. I have attached a picture on the crossover. I need to identify which colored wire (blue, pink and yellow) goes to which tweeter, midrange and woofer's positive terminal. Also, which black wire goes to each component. If anyone can tell based on the picture, it would be greatly appreciated. Thanks!
Appears to be...
Blue = Woofer.
Yellow = Tweeter. (You can see the Clamping diodes used to protect the tweeter).
Red = Midrange.
All blacks are common.
You can test the crossover by connecting the woofer to each one and listening
The switches should be labeled on the reverse side.
Hope that helps.
