3 weeks ago I ordered some Jantzen ribbon foil coils tor the woofer section of the crossover. The goal here is not louder bass but to see if the much nicer sound that was realized by using the ribbon foil coils in the other sections will translate into nicer bass. I tried to match the DCR as closely as possible but they are still 0.79 ohms as compared to 0.82 oms, so, 0.03 ohms less DCR. In this case I also ordered a complete set of Jantzen Crosscaps to go with the coils as well as Mills resistors. So these will be completely new boards and if the results prove to be much more sensitivity in the woofers I can simply swap the entire old boards back in. So, it's something like a €200 experiment that may or may not prove out.
The caps and resistors have arrived but I'm still waiting on the coils.
Also, I'm a little tired of dealing with wood screws when removing one of these boards to work on them. So I bought some little brass press nuts to insert into the backboard of the enclosure, as well as some M4 threaded brass rod and brass M4 nuts and plastic spacers. I'll cut some short lengths of threaded rod and end up with studs in the enclosure for mounting the boards and I can just slip them on and snug them down with nuts. Photos to follow when I get that mod done.
Cheers,
James
Cheers,
James
