I don't think their web site has been updated in many years. They seem to still be in business; are they not responding to phone calls at all?
An quick internet search shows you are not alone, and others have tried for years to get Spectral to respond to them. There are no Spectral dealers in the U.S., just the factory, so if they don't want to support their existing products, you are in for a tough time.
I have a Spectral DMC-12 that I was able to service with some input from prior designer Demian Martin, and then I figured out the rest. Fortunately many of the active devices are still available, but not all. I ended up replacing the power MOSFETs and caps and doing the needed adjustments, and fortunately the metal can transistors and the NPD op amps are good, but I ended up lowering the drive voltage a little because these run pretty warm and I want to eek out as many years as possible.
I've never seen inside a DMA-90 - is yours open so you can post a photo or two?
My avatar at the left is actually the same preamp:
