when unit was powered on at 33 rpm, it works fine at that speed as long as you want it to.switch it to 45 rpm, again works fine and pitch is good. same for 78 rpm.but if you are at 78 rpm or 45 rpm and try to go to any lower speed it will not go to the slower speed. basically you can switch the speed from low to high, just not high to low without turning the turntable off.
is this a problem that is fixable?
