brianjrealto
Well-Known Member
Just wanted to give my 2 cents on this vinyl record cleaning system...
Here is an example Ebay link, they usually run about $80..
http://www.ebay.com/itm/Spin-Clean-Record-Washer-System-/370198006284
I have cleaned over 30 records of my collection so far using the Spin clean. I have alot of other cleaning methods used before pulling the trigger to get this system.
It's manual, moving the records back and forth in the tray and takes a bit of time. But, this thing is fantastic and worth every cent!!!
I spin each record 15 times in each direction to really dig down in the vinyl grooves before removing and drying. I am amazed at the results!!
The benefits-
1) No more crackles or pops on playback, almost non-existant after cleaning
2) Sound quality/dynamics improve dramatically and brings 2nd hand vintage records back to life.
3) it cleans the vinyl record so well, your stylus won't need to be cleaned! I have played many hours of spin-cleaned records and my stylus needle is still spotless. (used to get fuzz balls and grime build up from previous cleaning methods with brushes or felt)
Conclusion... I think for the money, you won't come close to finding a better vinyl record cleaning system. I have never tried the high-priced machines and cannot attest to spending that kind of money. But, seeing that the stylus needle is spotless after playing alot of hours of records tells me that this system is top-notch and well worth the $80 or so it costs...
The benefits-
