Spinning too fast
blumule
Member
Turntable in question is a technics sldl1. Been great then all of sudden it’s spinning too fast . Belt looks good . Im no audio tech guy . What do yall think ? It doesnt have a conventional arm . This arm slides across the record by motor , gears and belt .
Clean the speed change switch and the adjustment trim pot on the circuit board that sets the motor speed. Check the 45 RPM speed. If it's ok, then the trim pot or the switch could be dirty. If the 45 rpm is off, it could be the motor.
