currituckco
On the phone pic, adjust the scope to the next higher sensitivity range to see your input better, with the tilt on your square waves something looks wrong at 1K. Is the common lead of the opt grounded? Do you have a 16 ohm load resistor connected? You should be using a higher signal input and output, you want about 5v at the output at the 8 ohm tap
I didn't see it in the text, I may have missed it, Is the driver board a SCA35 also?
try removing C3 from the board. C3, C6 and C7 are all transformer dependent C1, C4 and C5
might need to be increased to flatten the tilt, Dave would have a better idea than I for sure.
I'm using the 8ohm taps, and I have 8ohm/100w resistors as dummy loads. The driver boards are ST-35 (not SCA-35). I'll take a look at those cap values next. Thanks for the input.
