4 section Can caps generally go for between $36.00 and $48.00. The values and voltages are geared more for Guitar amps not audio gear, unless you go with a custom can cap. Also some are extremely hard to de-solder, so re-stuffing in place makes sense.
4 radial Electrolytic caps of sufficient value, voltage, and a small enough casing, can be had for less than $10.00. If you use a multi tool in the saw mode you don't have to remove the bottom of the old can from the chassis. Remove the top, gut it, install the 4 caps (with insulation on all leads, drill 5 holes in the bottom (1 for each section positive and 1 for the combined ground) and solder them all up.Use JB WELD on the top/bottom joint and clean up the rough spots. And you're done.
If you have an old CB antenna with the pl-259 connector on it, check fit it. If it fits, de-solder it from the CB antenna and solder it on to the Antenna. Problem solved.
The 200B has a converter on the 300ohm side between the input screws and the 300-72ohm switch. So no need for a 300-72 ohm or vice versa balun. Just connect direct to the side you have already run.
Thanks for the confirmation on Gadget's hunch. I'll order the adapter so I can run my coax directly to the SO-239. BTW I always take the manual into photoshop and combine the schematic into one page, and print on 13 x 20 matt card stock. I was unable to do this as the pdf has had a security code attached to it. I have tried vintageshifi and fisherconsoles and both service manual downloads have need a password to open in PS. Let me know if you have a different source and I will give that a try.
Update: This site has a few service manuals as a sticky. They have 2 for this model and they are not locked. I will post a download once I get the schematic done.
Sruddy, that's looking good, there are a few knobs on that auction site as we speak. (No Affiliation). Your dial glass isn't that bad, i wouldn't loose any sleep over it, you did good! AL
I saw those and bid on one. I found out today both auctions the seller had going, I think a total of two knobs in each, went for a total of over $170!!!!!
Are you kidding me??!! That's over half of what I paid for the tuner. Is this the normal going price for original knobs? They didn't even look like they could be brought back to like new. I have already tried one of the aftermarket caps. They were the ones with a recessed indicator. They had a very nice finish that matched the original double diamond, or star reflection but they were not deep enough and left space between them and the knob. The ones from China look like a great match as far as the shape and size however they looked to be tooled badly and don't have the nice original double diamond/star reflective surface. So I'm in the need of some knobs. In the meantime I can pull a set from a FM-200. They don't have brass caps though, and this will be sitting next to my X-202-B and they should look similar.
Thanks Al, I guess you just never know what will happen with the printing. I once ruined a glass using plain water. Now I know just because your test point passes doesn't mean all the printing will pass.
I have the all the parts for the power section ordered but still want to replace the 20 caps that aren't ceramic. I would like to improve the sound and or performance if possible. What brand of caps do you all like. Up until now I have used orange drops or gone with kits from Jim. Jim has no kit for the FM-200-B.
Also it looks like there are two filter caps on this tuner. This is the first time I have worked on a unit with this design. I'm assuming it is this:
- An improvement in circuit design is where an AC radio has two line-to-ground capacitors (see below schematic) to filter both sides of the line. This will give you better power line filtration and you don’t have to worry about polarity when you plug in your radio. However, let’s not complexly knock the single bypass design as some early AC tube radios used NO line filter capacitors at all.
Here is my schematic. I'm assuming it is essentially the same as above.
They look to be .01 600v. Shall I use my usual X1 Y2 safety caps?
