Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
I have it apart but I think I might be able to turn it on. I do that and take photos tomorrow am. I also have to figure out how to post a photo on here.
The second picture shows one power amplifier channel. The trim pot visible on that picture is for the bias current adjustment. There is no offset adjustment. The two transistors TR601 and TR602 are most probably the ones for the input differential stage. It is something that you can easily check. If you follow the circuit from the base of one of the transistors (probably TR601), you should reach the terminal 1 or 2 visible near the edge of the board. These terminals seem to me to be the input terminals for that channel, one for the signal and the other for the ground. The emitters of TR601 and TR602 are probably connected together under the board.
The important point is that TR601 and TR602 (if what precede is exact) must be matched (have the same hFE) in order to have the least amount of DC voltage at the output. This is this DC voltage which is responsible of the thumb noise at turn-off. But this condition is not sufficient. Sometimes we need to change some components on the board. We will see later what you need to do exactly, but your first action at this point should be to take a measure of the hFE for the differential transistors. TR601, TR602 on one board, and the corresponding transistors on the other channel's board partly visible on the fourth picture.
Do you have a meter with a hFE scale?
The STA-960 and STA-850 are very different from what I see on your pictures. Unfortunately, the schematic I did for the 850 is useless for your receiver. We will need to work from the pictures you will provide.
It might be normal for that piece of equipment. I used to own one. Turn off the speakers by switching the selector switch to out before turning off the receiver.
That's a practice I still adhear to...Before I power down a unit, I'll take the volume to zero, then disengage the speakers, followed by a power down...and I'll unplug the unit when I leave the house.
No more voltage spikes screwin' up my stuff.
