markd51
Nyuk Nyuk
What are you running? SS? Tube?
A year or so back I finally took the plunge and added an Opera Consonance PM-1 tube phono stage to my set up. Until then I'd been using the phono stages in one integrated amp or preamp or another. They sounded very good, especially the Yamaha C-4 but the PM-1 was a quantum leap forward in every way. Much more detail and clearer, deeper soundstage and simply more presence. The bottom end is also quite astounding.
If I have one slight caveat it is that it can be a bit "hot" with some LPs and I'd like to replace the Jan Phillips tubes with something a bit warmer, preferably current issue and not too pricey. Suggestions welcome!
I have a CAL Alpha DAC, that I bought used, and came with JAN Phillips, installed by the previous owner. I thought they were an absolutely horrible tube, and quickly sought out others to use. After some tube swapping, my suspicions were right.
As I gather, your Opera Consonance uses two 12AX7 Tubes. Not sure if you can use others, such as the 5751 Tube?
One can virtually empty a bank account on a pair of matched-graded NOS 12AX7 types, by the likes of Telefunken, Amperex, Mullard, Pope, etc etc etc.
Two cheap tubes worth trying, which won't break the bank, and in either case should sound better than the JAN Phillips, would be the Sovtek 12AX7LPS, and the Sovtek-New Sensor 12AX7 Mullard Re-Issue.
Both are quiet tubes, the Sovtek LPS will probably be a more neutral tube, and the Mullard Re-Issue being a bit warmer. Mark
