standard audio tests
ferninando
Lunatic Member
I ran across this item in my ref. library of audio/electronics liturature.
THE TEKTRONIX COOKBOOK OF STANDARD AUDIO TESTS using the 5L4N low frequency spectrum analyzer. A-3107
rev 2/11/75
Has test setups,load matching. tests include power out, freq. resp., harmonic dist, IM dist. Pwr bandwidth, damping factor, s/n ratio, sq. wave resp. crosstalk, sensitivity.
Servicing Hints and test forms.
Altho written for a spec. analyzer, I'd gess scopes and other test equipment could be used as well, knowing what you're doing.
Great reading for the tekky inclined or just to learn about audio testing in general. Worthy of any AKrs time to locate one.
Just thought you mite like to know such a reference exists.
PS: it's a 20 pg. field/service center document.
