Thanks to all who weighed in to help me.
Well, I had not had any luck prior, but emailed Stanton again this morning and received the reply below.
I'm guessing the force the brush exerts changes (lessens) as it is pushed higher up its pivot point and the angle of LP contact lessens from vertical to about 45 degrees. I measured 1 gram as the brush first touches my scale, but have no good way to dynamically measure while the plater is turning so I will trust the 1/2 gram recommendation Stanton made below is based upon their ability to make a take a more accurate measurement or make a better guess. I was tracking my old 680 EEE brushless stylus below .75 grams (with "The Clamp" brand reflex clamp) so I will set the VTF now at 1.25 grams gross allowing for .5 grams of brush = approx. .75 net and leave my antiskate setting at the (net) .75 gram setting.
Hi Greg,
½ gram is what we suggest some people go with a full gram.
Thanks Robert Strachan aka Dj jungle boy
Technical Support Specialist:
DJ@StantonDJ.com
954.316.1500 x2257 : 954.316.1590 (fax)
stantongroup.ws :: Cerwin-Vega! : KRK : Stanton
Speaking to quality control, I've been hearing this a lot. The good ones are great, and the bad ones problematic.
