I'm starting with fully recapping and replacing some recommended semi's on a 2245.
I've noticed that both channels work ok on AM/FM/Phono/Tape but the Right channel is out on Aux. Does Aux input go thru a different board than the others? (Decoder board for example) Can defective caps only effect Aux vs others?
My plan is to recap and de-ox everything properly before concluding anything, but wondered if any of the pros out there would venture an educated guess on what is the most likely problematic board or culprit before I got there.
Thanks
Thanks
