Perkinsman
"I've never met a fixer that I couldn't break"
I've read thru a number of posts here see that this forum has some very experienced 1000a people. I wanted to check in before I get too far along in restoring this unit. I've been mostly working on Marantz units but I also work on tube amps and understand the voltage dangers present and will be discharging the main caps each time I shut down.
So far, I've just replaced the aluminum ecaps with new Elna Simlic's/Nichicon of higher voltages to exceed the SV's I've seen printed on the original caps.
I don't have much experience with PIO caps and noticed that there are quite a few in this unit. I happen to have a good number of Russian pio's of the correct value so it's an easy fix if needed. Do these routinely get replaced as do the aluminum ecaps during restoration?
Are replacement cap cans readily availbable for the main caps or do most people restuff the old ones?
Are there any specific components other than what I've mentioned that should be replaced (or ones that should NOT be replaced) on this unit?
