FireGuruMN
I have a beautiful 1960 console stereo if working condition. But I need to do the basics:
Make it safe
Make it sound good
Make it stay that way
Before (and after--it's just perfect the way it is)
First the SA100 amplifier:
1) It still has several of the original Fisher tubes. I have not run any of them through a tester but I don't want to use them. I prefer to preserve them and burn through some less historic tubes. From my internet searching it seems that Sovtek EL84M's are the preferred choice. And a Sovtek rectifier tube should be fine also. I think I will use the Fisher phase inverters as they should last for ever anyway and replacements are expensive. . .
2) All the "brown drops" are mylar capacitors. So no need to replace them, right? Maybe there are better choices available today? I like Solens.
3) What do the 4 AC/DC pots do? I plan to leave them alone, right?
4) Is there a schematic to provide individual bias for each tube?
5) Replace the 3 red electrolytics and the multcap can. Any preference for buying a new multicap versus putting caps under the chassis?
6) Should I add a "surgister"?
7) Changed to a grounded cord so I don't have to worry about polarity?
8) Replace the selenium diode.
9) One rebuilder was very worried about grounding to the copper chassis developing a resistance due to dissimilar metals over time. Should I worry too?
There were burn marks on the back of the cabinet where the amplifier was located so there has been some drama over the years.
Before:
The 202T tuner/preamp:
10) Again, mylar caps all over so no need to replace them.
11) Selenium rectifier has to go for safety reasons. Any recommendations for a silicon part? I have a Onkyo M504 parts unit with some monster rectifiers I could use.
12) Lots of multican caps in this preamp. Maybe leave them alone or is that just asking for trouble?
13) Remove the pottery. yes, someone put a piece of terra cotta pottery near the power switch for some reason. Along with a piece of metal. Place jokes about leaky pottery here. Anyone know what that could be doing there? The power switch seem somewhat loose. It is tight to the face plate but wiggle some when turning on/off.
14) Remove the death capacitor. Should I replace it or just put in a grounded plug so it is not necessary.
15) Display bulbs are burned out. Anyone have a part number?
16) There is a black bare wire hanging out of the shielded area in the back. Any thoughts? its right below the round ceramic cap in this picture.
Speakers:
17) I have new Solen capacitors in hand. Are there any resistors other than the potentiometers?
18) I heard some concerns about the horn tweeters being problematic. Are they valid concerns? I have not heard the speakers except with a poor FM signal so I cannot say how they sound?
Turntable:
19) I'm just going to make it look nice but probably not use it. Anything necessary to make it safe?
General:
20) How do I get rid of 60 years of cigarette smell?
Thanks for making it through all 20 questions. This is my heaviest piece of audio yet and I own some Phase Linear monsters! The best thing is that my wife wants this in the living room as soon as the cigarette smell goes away. How many AK members have had that happen?
Make it safe
Make it sound good
Before:
Speakers:
Turntable:
General:
