Hello!
I am new to AudioKarma, and relatively new to vintage audio equipment, so I would appreciate any insight you all might be able to offer.
I have a problem with static and popping / no audio in my system. I've isolated the problem to the receiver, which is a Pioneer SX-727. The receiver was professionally cleaned/serviced in January 2016.
My problem is especially frustrating because it is extremely inconsistent. Sometimes my system will play perfectly for a short period of time (10-30 minutes) before popping out and going silent. Sometimes it will play audio with static and popping coming from the left channel only. Sometimes it will only output static and popping that cannot be isolated to a particular channel. Sometimes I'll turn it on and it won't put out any noise at all.
The static and popping does not change in volume when I adjust the volume on the receiver. When it can be isolated, it is located in the left channel. When present, the static and popping persists on all channels (A,B,C, and headphones). I don't know that it makes any difference, but the static/popping is still the same whether I use phono 1 or phono 2 as my input.
Any ideas about what's wrong with it would be appreciated. Also, I don't trust myself to repair it on my own, so if you have any idea how much it would cost to repair, that would be good to know. I'm pretty attached to this receiver, but if it's just going to be a money pit I might move on to another receiver.
Thanks in advance for your help!
Amanda
Amanda
Not that I can see, unless he squirted DeOxit in the connections (and there ain't many on a 727) and put them together and pulled apart to clean them a few times, as most everything is wire-wrapped and or soldered. . You could do the same thing except check it for operation with test gear. Your test gear is your speakers and headphones.
