Adriancotter
Member
I have just added Wharfdale Linton Hertiage speakers to my current set-up. My old set-up which I have been running for the last 18 months without incident consisted of a Pioneer PL514 turntable hooked up to a Marantz 2265 integrated amp (earth cable from TT to earthing lug on amp) and to Wharfdale Diamond 9.1 speakers. Diamonds were bi-wired utilising both Speaker A and Speaker B outputs on the amp. No issues, All records used and new ultrasonically cleaned before using so no static issues.
So, I hook up the new Lintons to the speaker A output and bi-wire the Diamonds to the speaker B output. Need both hooked up for the moment as the final position of the Lintons requires me running cables under the floorboards, which I haven’t gotten around to yet. Currently just trailing cables across the floor to the Lintons, so when not in the humour to do that, I listen to the Diamonds.
Now, to the problem at hand, whenever I connect up the Lintons and only when I connect the Lintons, I have been receiving static shocks from the TT and on one occasion from the volume knob of the amp. TT grounding to amp is exactly as before. I am aware of the issues wearing synthetic clothes and rubber soled shows, getting up and down off the sofa etc...and that may be a factor but as I’ve said, none were an issue before and it only happens when the Lintons are connected to the system. If I ground myself off the fireplace before touching the TT, no problem.
I have given my wife a shock by touching her, it seems like their is an increase in the amount of static in the room when the Lintons are powered up.
Any theories or suggestions please.
