Treat your records with one of the anti-static treatments and you’ll be rid of static for the life of the record. Records that I treated 30 years ago with Permostat or Sound Guard are still anti-static - even if you give them a good rub with a record brush or cloth, they never get static. In fact, when those treatments first became available in the 1970's, many hi-fi reviewers tried drastic treatement such as rubbing treated records on nylon carpets and other things, but could never induce static on them ever again! Following are a list of the anti-static cleaner or anti-static preservative treatments I know of – ones marked NLA are no longer available, but may occasionally be sold unused or virtually unused on secondhand markets:
AM Record Cleaner – anti-static record cleaner/preservative
Bib XL-2 Groov-Guard – anti-static record preservative (NLA)
Blaxland Scientific Discprotec – anti-static record preservative (NLA)
Metrocare Discguard – anti-static record preservative (NLA)
Nagaoka Stat-10 – anti-static record preservative
Milty Permostat – anti-static record preservative
Pfanstiehl Pfan-Stat – anti-static record cleaner/preservative
ReLoop Record/CD Cleaner – anti-static record cleaner/preservative (I think this is anti-static, although I can’t find much info on it, and haven’t tried it myself)
Rozoil Gruv Glide – anti-static record preservative
Ball Corporation Sound Guard – anti-static record preservative (NLA)
Static Cleaner – anti-static record cleaner/preservative
Ones I've tried and which definitely work well to remove static permanently are Sound Guard, Permostat, AM Record Cleaner and Static Cleaner, but the others also advertise to do the same thing, so should be OK - it's just that I've never used them, so can't confirm their efficiency.
The most easily available ones those made in the same country or area: Gruv Glide and Pfan-Stat in North America, Permostat in Britain, and AM Record Cleaner in Denmark and other parts of Europe. In Australia AM Record Cleaner and Static Cleaner are easily available from many DJ supply and record shops - they seem very similar, even appearing in similar shaped bottles, with an application cloth in the lid.
