stepped adj. pots - Make before Break?
dogwan
Dogwan
I want to replace some crappy old variable resistance adjustment pots with a multi-position rotary switch using discrete resistors.
On a speaker crossover my instinct tells me this should be a shorting (or Make before Break) switch to protect the Mid and Tweeters. Am I correct?
Don't bother. Schem. probably won't tell you. Besides, I'm not going to use a slide switch in this application.
AFAIK, the toggle switches used were regular switches, not make before break. IMO, that's not a big deal in a crossover though I wouldn't switch anything at high volumes. Usually people worry about make before break with stepped attenuators at line level, to avoid pops.
