Stepstools As Speaker Stands
Patriot1776
Cancer Survivor at 26
Okay, I've decided the best way to significantly reduce any rumble problems in my turntable is going to be getting my speakers up off my floor. My speakers are a pair of Pioneer CS-G2000's and for where I live, yard sale stepstools are going to be the least expensive option. Any recommendations on height and leg style for maximum stability and best isolation from the floor?
I don't know that speaker. How big are they and how much roughly do they weigh?
hah, hey I thought I was the only one that did that! I used to have my Sansui SP-1500's on 2.5' stools which helped the bass a LOT, and it put them right at ear level when I was seated as well. Not sure of the heigth you should use, but I would say whatever puts them at ear level will be good. Experiment!
If the stools have metal legs, try this: Turn them upside-down. Remove the end pieces (that close off the ends of the metal leg tubes). Fill legs with sand. vibrate/shake/tap to settle the sand, and top it up. Repeat a few times until the legs are well filled. Replace end pieces. Make sure the replaced ends are secure; add glue if necessary. Turn the whole thing back right-side up.
Now you have heavier, sand-damped speaker stands. Obviously, this only works for some kinds of stools; you can't fill the legs of wooden stools!
I've used this approach, as well as some nice Chinese hardwood stools as stands before. It can work very well, and if you get the right woodgrain, look very good, too, but it requires picking appropriate stools. Lightweight or overly resonant ones won't work quite as well as "real" stands.
Another thing that can improve a stool as a stand is to put a heavy slab of stone or a paving block on top of the stool, under the speaker, to help add mass and stabilize it. The speaker can be spiked to, or blu-tacked to, the stone block, which can be covered with decorative cloth for higher WAF.
I would say 10" to 1 foot off the floor would help them sound Great:yes: Mine are about that size and about 55lbs
I have noticed at the Thrifts small wooden childrens chairs. Remove the backs / arms, and paint.
Nope, 10 bucks for both from Wally World. And they match the rack, sorta.
Cinder blocks will do a far better job than any stool, chair or milk crate. And they are about $2 each.
Flimsy stools and chairs will rob speakers of physical stability, not allowing you the benefit of their full potential.
Bass frequencies and accuracy improve when a speaker cabinet is held stable. When a driver pushes out on the air in front of it, any backward counter-movement of the cabinet robs it of potential to do what it is trying to do. You want the driver to press out from as stable a platform as possible.
Elevating speakers is a terrific opportunity to get some mass under them. Try it and see. Orient the blocks with the holes facing out so you can see the wall from the listening position. Just be careful not to scratch the floor of it isn't carpeted. (I used rubber carpet lining or the similar stuff that goes on shelving.) And you can drape the blocks with some fabric of your choice if you don't like the bare cement look.
Years ago, when I switched from milk crates to cinder blocks, the difference was not subtle. It was like getting a new pair of much better speakers! (They were AR93's, btw). Then try spiking them to the cinder blocks. That's improve things even more. Should tighten up the bass, clean up the mids, and improve imaging.
My $0.02
Have fun :thmbsp:
Wal-Mart folding/locking stools on sale for $9.99 each.
Hack-sawed the legs to shorten them up a bit. Removed the foam pads and drilled out the spot welds on the metal tops and removed them. Stained a couple chunks of 3/4" X 8" X 8” red oak and screwed on from underneath to serve as new tops.
Not really what I'm looking for but will do for now.
