Simply a TT or CDP directly into a little Grommes 10w mono amp. I am ready to start restoring the amp (replacement pots and caps are on the way) and didn't want to damage the new work when I'm done. I have no working mono sources to use with it.Dusty Chalk said:but this is...a DAC? Or a pre? It's not a tubed phono stage or something with a really sensitive output transformer?
It's called a mixer.ozmoid said:I was also curious if there was a schematic for a stereo>mono downconverter (?) ...
Doesn't exist. The issues I mentioned are rare, so I wouldn't worry too much about it -- just warn you that mixing to mono may cause familiar stereo mixes to sound a little odd. If you try to correct for them, I suspect you will accidentally end up cancelling up any normal central sounds that are the same in both channels....that would rectify any issues like the phase cancellation.
Yup, that should work.Maybe a pre-amp with a mono setting?
Yes.From your post, it sounds as if I will be dealing with different issues based on the actual recordings used. Won't that be fun!
OK, that's what happens when a perfectly rational person tries to make things too complicated. :twak: I even use one on a near weekly basis. I have two available to me for personal use right now. I will need to find something a little smaller for permanent installation with the Grommes.Dusty Chalk said:It's called a mixer.
Finding a tube pre would be the best solution, but it may be quite a while before I can find something appropriate.Justen said:I have used one of my receivers as a pre-amp, then I found a Dynaco pre-amp. I just run my stereo in and taker mono out. Seems to work fine to me... as well as the mixer the sits 15 feet away does. But why complicate things? Let your stereo be complex, let your mono rig be a system of complete simplicity...
fotno said:Having heard that very mono system Justen, I'd vote for doing it your way! You know that listening to yours is why Oz has been on this so hot and heavy right?
:lmao: :lmao: :lmao:macaltec said:He tends to have that effect on people. I was a normal, well adjusted person, happy with my BPC until I met Justen. Thanks dude :thmbsp: , who wants to be normal?
Justen said:Puhleeezzz! You weren't nuthin' near normal when we met! I'll take a wild guess that when we met you had at least 15 receivers and 20 pairs of speakers...
Oz, if my humble system started you down this path I either apologize or say congratulations! I think I'd get rid of my one remaining stereo rig before I'd ever consider getting rid of the mono rig...
What cableguy said.Justen said:,,,my humble system...
:lmao: :lmao: :lmao:macaltec said:Humble my @$$.
